Knowledge Base Article
Why do I see two duplicated "Enable HIP Reconfig interface" option in Multi Channel DMA FPGA IP for PCI Express* of F-Tile parameter editor?
Description
Due to a problem in Quartus® Prime Pro Edition Software version 24.1, you might observe that there are two "Enable HIP Reconfig interface" check boxes in IP parameter editor GUI.
Resolution
The first check box is the right and only one needs to be checked to enable HIP reconfig interface.
This problem is fixed in Quartus® Prime Pro Edition Software version 24.3.
Updated 4 months ago
Version 7.0No CommentsBe the first to comment
