Knowledge Base Article
Why do I see timing problems reported when using derive_pll_clocks using UniPHY-based memory controllers?
Description
Due to a problem in the Quartus® II software version 13.0 SP1 with patch 1.dp5, you will observe certain warning messages during the Fitter stage of compilation as well as Report DDR issues within TimeQuest timing analyzer when the following criteria are met:
  • derive_pll_clocks is called in a Synopsys Design Constraint (.sdc) file after the .sdc files generated with the UniPHY-based megafunction
  • UniPHY-based DDR2 or DDR3 memory contoller used with the following frequency ranges:
Device
Memory Frequency (MHz)
Cyclone® V E/GX/GT
250 <= f <= 400
Arria® V GX/GT
250 <= f < 450
The following warning may appear during static timing analysis using TimeQuest timing analyzer:
Warning (332088): No paths exist between clock target "<variation name>|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk" of clock "<variation name>|altera_pll_i|general[0].gpll_afi_clk" and its clock source. Assuming zero source clock latency.
Resolution
To work around this issue, download and install the patch below. The Quartus II software version 13.0 SP1 patch 1.dp5 must be installed for the patch below to function properly.
The EMIF IP must be regenerated and the design re-compiled after the patch above is successfully installed.
This issue will be fixed in a future version of the Quartus II software.
Related Articles
Updated 4 months ago
Version 4.0
