Knowledge Base Article
Why do I see the fitter error "Can't place multiple pins assigned to pin location PIN" for AVSTx8 data signal?
Description
Due to Avalon-ST x8 mode uses the SDM_IO bank, which is dedicated IO for configuration signal, AVSTx8 cannot place to userI/O pins.
In Intel Stratix10® pin connection guide page7, table3. Avalon-ST x8 mode uses the SDM_IO pins. SDM IO bank is dedicated IO for configuration signal, cannot locate user I/O.
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/dp/stratix-10/pcg-01020.pdf
In Stratix10 Configuraition User Guide page12, table4, it said AVSTx8 signals are dedicated, cannot use dual purpose user IO.
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/hb/stratix-10/ug-s10-config.pdf
Only dual purpose configuration pins can user as user I/O during user mode. It describes in note15. AVST_DATA, AVST_VALID, and AVST_CLK.
Updated 11 months ago
Version 3.0
