Knowledge Base Article
Why do I see functional failures on the paths involving High-Voltage IO bank input buffers in the Agilex™ 5 designs?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2 and earlier, you might see functional failures when compiling the Agilex™ 5 designs. A timing model miscorrelation in High Voltage I/O (HVIO) bank input buffers (IBUF) results in inaccurate timing analysis. The miscorrelation can range from 0.7 to 2.5 ns.
The problem affects the Agilex™ 5 FPGA E-series and D-series designs using input pins in HVIO banks. High Speed I/O (HSIO) banks are not impacted.
Resolution
To work around this problem, download and install the patches below for the Quartus® Prime Pro Edition Software version 24.2:
The problem is fixed starting with the Quartus® Prime Pro Edition Software version 24.3.
Updated 8 months ago
Version 3.0
