Knowledge Base Article
Why do I see FCS or CRC errors on a link partner or Ethernet tester when the “Packet Client Loopback” is enabled on my F-tile Ethernet Intel® FPGA Hard IP design example?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1, you might see FCS or CRC errors on a link partner or Ethernet tester when the “Packet Client Loopback” is enabled on the design example of the F-tile Ethernet Intel® FPGA Hard IP.
Resolution
To work around this problem, write 32’h0000_0000 to the cfg_rom_pkt_gap_addr (offset 0x1C) register. For the single IP instance design example, this register can be found at absolute offset 0x0010_001C.
This problem has been fixed starting from version 23.2 of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
