Knowledge Base Article
Why do I see Error (20354) and Error (20353) when signing CCERTs in Quartus® Prime Pro Edition version 26.3 with root keys generated in earlier versions?
Description
You may encounter a signing failure in Quartus® Prime Pro Edition Software version 26.3 when an Agilex® 7 FPGA device root key generated by quartus_sign in an earlier release, such as Quartus® Prime Pro Edition Software version 21.2, is used to create and sign compact certificates (CCERTs).
The operation fails with the following errors:
Error (20354): Fail to execute file <path>26.3/111/linux64/devices/programmer/python/agilex_sign.py
Error (20353): Module: bitstream.py, Function: verify_block0, Line: 798
Error (20353): Root key select is undetermined
Error: Quartus Prime Signing_Tool was unsuccessful. 3 errors, 1 warning
For example:
In Quartus® Prime Pro Edition Software version 21.2, the following files were generated:
- root0_212.qky
- root0_public_212.pem
- root0_private_212.pem
- root0_aes_212.qek
After switching to Quartus® Prime Pro Edition Software version 26.3 to generate the AES CCERT, the following commands were executed (using the AES CCERT test case as an example):
quartus_pfg --ccert -o ccert_type=EFUSE_WRAPPED_AES_KEY -o qek_file=root0_aes_212.qek unsigned_aesccert0-263.ccert
quartus_sign --family=agilex --operation=sign --pem=root0_private_212.pem --qky=root0_212.qky unsigned_aesccert0-263.ccert signed_aesccert0-263.ccert
Impacted Agilex 7 OPN
- AGF 012
- AGF 014
- AGF 022
- AGF 027
- AGI 022
- AGI 027
Resolution
Recommendation:
To sign a CCERT, use one of the following options:
- Use the same Quartus sofware version that was used to generate the existing root key.
- Use Quartus Prime Pro Edition Software version 26.1.1 or earlier.
- Use Quartus Prime Pro Edition Software version 26.3 or later to generate a new root key.
- Note: This behavior applies starting with Quartus Prime Pro Edition Software version 26.3 and is not expected to change in future releases.
Related Articles
Updated 10 hours ago
