Knowledge Base Article
Why do I see Error (18950), Error (18948) and Error (209012) when program SOF file for Agilex® 5 FPGA device in Quartus® Prime Pro Edition version 26.3 ?
Description
You may encounter programming failure in Quartus® Prime Pro Edition Software version 26.3 with an Agilex® 5 FPGA device SOF File.
The operation fails with the following errors:
Error(18950): Device has stopped receiving configuration data
Error(18948): Error message received from device: Failed to load firmware due to authentication failure. Ensure the firmware is signed with the correct signing key.
Error(209012): Operation failed
Impacted Agilex 5 OPN
  • A5Dx130xxxxxxxx
  • A5Dx160xxxxxxxx
Resolution
Contact Altera Support team for the patch file.
Related Article
Updated 54 minutes ago
Version 3.0
