Knowledge Base Article
Why do I see configuration failure "Error(18948): Error while sending VOUT_MODE command" if the PMBus Slave device type is set as XDPE12284C or PXE1410CDM_G005 for Agilex® 7 FPGA in Quartus® Prime Pro Edition Software version prior to 26.1?
Description
Due to a problem in Quartus® Prime Pro Edition Software version prior to 26.1, when you select the "Slave device type" as XDPE12284C or PXE1410CDM_G005 in the Power Management & VID settings page in your design, you may see the following error while programming SOF file with Quartus® Prime Pro Edition Programmer:
Error(18948): Error message received from device: Error while sending VOUT_MODE command
Resolution
In Quartus® Prime Pro Edition Software version prior to 26.1, if you are using XDPE12284C or PXE1410CDM_G005 as the PMBus Slave device for Agilex® 7 FPGA, select the "Slave device type" as "others" in the Power Management & VID settings page as shown in the table below.
Voltage Regulator
Slave device type
Voltage output format
Coefficient
Voltage value unit
XDPE 12284C (IMVP9 mode)
Others
Direct
m=1, b=-200, r=-1
millivolt
PXE1410CDM_G005​
Others
Direct
m=2, b=-490, r=-1​
millivolt
This problem has been fixed in Quartus® Prime Pro Edition Software version 26.1.
Updated 7 months ago
Version 2.0
