Knowledge Base Article
Why do I see bit errors when internal serial loopback is enabled for the Agilex™ 7 FGT transceiver manual adaptation mode designs?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1 and earlier, the internal serial loopback enablement sequence for the Agilex™ 7 FGT transceiver manual adaptation mode is not optimal. You might observe an unexpectedly high bit error rate (BER) when an external signal is present on the receiver's input.
Resolution
To workaround this problem, before enabling the internal serial loopback, you can adopt one of the following two methods:
- Disconnect FGT RX from the external cable or module
- Drive the external source signal in tri-state or electrical idle
There is no plan to fix this problem in a future release of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
