Knowledge Base Article
Why do I see an incorrect read latency when simulating the eSRAM Intel® Stratix® 10 FPGA IP?
Description
You may see an incorrect read latency when simulating the eSRAM Intel® Stratix® 10 FPGA IP because the IP instantiates a gate model CPA block for simulation, which can cause a hold violation at the PHY interface.
Resolution
To work around this in simulation, do the following.
1. Open IP_generated_dir/esram_<>/sim/<>_esram_191_<>.sv
2. Search defparam fourteennm_cpa_component.pa_sim_mode = "long";
3. Change to defparam fourteennm_cpa_component.pa_sim_mode = "short";
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition software version 20.1.
Updated 1 month ago
