Knowledge Base Article
Why do I see an extra read data valid assertion on the Intel® Arria® 10 FPGA EMIF MMR interface?
Description
If your Intel® Arria® 10 FPGA memory controller Intel® FPGA IP has the MMR interface enabled, you might notice that the mmr_readdatavalid signal asserts occasionally even when no read commands are issued.
The mmr_readdatavalid assertion originates from the memory controller's internal read command and could cause the Avalon® host interface to capture the wrong read data.
Resolution
The Avalon host interface must only accept mmr_readdatavalid based on the following requirements:
mmr_readdatavalid returns one cycle after issuing read request to MMR register ecc1, ecc2, ecc3, ecc4.
mmr_readdatavalid returns three cycles after issuing read request to all other MMR registers other than ecc1, ecc2, ecc3, ecc4.
Example: The Avalon host interface should only accept mmr_readdatavalid one clock cycle after sending read request to register ecc1 (with mmr_waitrequest signal low).
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
