Knowledge Base Article
Why do I see a fitter error(21843) when bypassing RX auto adaptation for FGT channels by qsf assignments?
Description
You will see fitter errors like the one below when bypassing RX auto adaptation for FGT channels by qsf assignments, as described in chapter 3.12.2. FGT PMA Settings of UG20315.
Error(21843): user.bb_f_ux_tx[3] -> IP_INST[0].hw_ip_top|dut|eth_f_0|hip_inst|per_xcvr[3].x_bb_f_ux|x_bb_f_ux_tx
Error(21843): flux_mode == FLUX_MODE_CPRI
Error(21843): is_used == TRUE
Error(21843): location == UX8
That is because the qsf assignments in the latest F-Tile Architecture and PMA and FEC Direct PHY IP User Guide are not enough. Besides the assignments, you should add "set_instance_assignment -name HSSI_PARAMETER "flux_mode=FLUX_MODE_BYPASS" -to <TX_SERIAL_PIN>] -entity" also.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 24.3.
