Knowledge Base Article
Why do I see a DRC TMC-20026 warning when using the EMIF for HPS IP in the Agilex® 5 SoC FPGA designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 24.3.1 and earlier you may see the next DRC Warning when using this IP.
TMC-20026 - Empty Collection Due To Unmatched Filter: hps|emif_io96b|emif_io96b|emif_0_lpddr4|emif_0_lpddr4|*.arch_0*div_reg
Resolution
You can safely ignore this warning.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.
Updated 5 months ago
Version 5.0No CommentsBe the first to comment
