Knowledge Base Article
Why do I receive an error when using the Intel® Quartus® Prime Programmer version 20.3 to enroll the Intrinsic ID PUF or perform Black Key Provisioning on an Intel® Stratix® 10 device?
Description
Due do a known problem in Intel® Quartus® Prime Pro Edition and Intel® Quartus® Prime Programmer software version 20.3, you may encounter an error loading the provision firmware onto an Intel® Stratix® 10 device that has the owner root key hash programmed into physical eFuses.
Resolution
A patch to fix this problem is available for the Intel® Quartus® Prime Pro Edition software version 20.3
Download and install Patch 0.05fw from the appropriate link below
Download patch Intel® Quartus® Prime Pro Edition 20.3 Patch 0.05fw for Windows (.exe)
Download patch Intel® Quartus® Prime Pro Edition 20.3 Patch 0.05fw for Linux (.run)
Download the Readme for Intel® Quartus® Prime Pro Edition 20.3 Patch 0.05fw (.txt)
This problem is fixed starting from Intel Quartus Prime Pro Edition software version 20.4.
Updated 4 months ago
Version 4.0
