Knowledge Base Article
Why do I not see DQS tracking signals when I implement UniPHY based DDR3 SDRAM Controller above 533MHz?
Description
In Quartus® II software version 11.1SP2 and earlier, the DDR3 SDRAM UniPHY based controller IP turned on the DQS tracking feature at speeds above 533MHz so the signals afi_ctl_refresh_done, afi_seq_busy, and afi_ctl_long_idle for the DQS tracking were present in the IP.
In Quartus II software version 12.0, upon further analysis it has been determined that DQS tracking is not needed in Stratix® V devices at any supported frequencies so the feature has been disabled.
Resolution
Regenerate the DDR3 SDRAM UniPHY based controller in Quartus II software 12.0 to get the most updated version of the IP.
Updated 11 months ago
Version 3.0
