Knowledge Base Article
Why do I get the following error message when using the Triple Speed Ethernet IP : "Error: Family name "Stratix II" is illegal Error: eth_tri_1port: HDL generation failed"
Description
This error occurs when you generate the Triple Speed Ethernet® IP with simulation enabled and you have installed Quartus® II with only a limited set of devices. For example, only Arria® II GX device support has been installed.
To workaround this error, you can simply re-install Quartus II ensuring that all device famlies are installed. Then regenerate the Triple Speed Ethernet IP.
This problem will be fixed in a future version of the Quartus II software.
Related Articles
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
