Knowledge Base Article
Why do I get the error “Unable to determine the execution environment” when running the “aocl version” command in the Intel SDK for OpenCL?
Description
Due to an issue in version 18.1.0 of the FPGA Runtime Environment for OpenCL™, the  command “aocl version” will produce the following errors:
aocl: Unable to determine the execution environment of the FPGA Runtime Environment for OpenCL(TM).
aocl:   Detailed error: Could not find SDK internal libraries directory /opt/intel/intelFPGA_pro/18.1/aclrte-linux64/linux64/lib
aocl:   Detailed error: Could not determine the path to SDK internal libraries
Resolution
The workaround is to run the following command to create the directory that the command is looking for.
$ mkdir -p $INTELFPGAOCLSDKROOT/linux64/lib
This problem is fixed beginning with the Quartus® Prime Software version18.1.1
Updated 11 months ago
Version 3.0
