Knowledge Base Article
Why do I get the error “‘clGetProfileDataDeviceIntelFPGA’ was not declared in this scope” when compiling OpenCL host code?
Description
The library function clGetProfileDataDeviceIntelFPGA must be called in the host code when dynamically profiling an autorun kernel.  If this function is called directly, the host code compilation may fail with an error like the ones below.
Linux (gcc)
    error: ‘clGetProfileDataDeviceIntelFPGA’ was not declared in this scope
Windows (Microsoft Visual Studio)
    error: unresolved external symbol clGetProfileDataDeviceIntelFPGA
If the system is using the ICD driver, non-standard functions such as *IntelFPGA functions cannot be used directly. The OpenCL call clGetExtensionFunctionAddress must be used to get a function pointer for the non-standard function and that pointer must be used to call it.
Resolution
Using the prototype of the function, located in CL/ext.h
    extern CL_API_ENTRY cl_int CL_API_CALL
    clGetProfileDataDeviceIntelFPGA(
            cl_device_id            /*device_id*/,
            cl_program              /*program*/,
            cl_bool                 /*read_enqueue_kernels*/,
            cl_bool                 /*read_auto_enqueued*/,
            cl_bool                 /*clear_counters_after_readback*/,
            size_t                  /*param_value_size*/,
            void *                  /*param_value*/,
            size_t *                /*param_value_size_ret*/,
            cl_int *                /*errcode_ret*/ );
Replace the function call
    cl_int status = clGetProfileDataDeviceIntelFPGA (device, program, false, true, false, 0, NULL, NULL, NULL);
with code using the syntax below
    cl_int (*get_profile_fn)(cl_device_id, cl_program, cl_bool,cl_bool,cl_bool,size_t, void *,size_t *,cl_int *);
    get_profile_fn = (cl_int (*) (cl_device_id, cl_program, cl_bool,cl_bool,cl_bool,size_t, void *,size_t *,cl_int *))clGetExtensionFunctionAddress("clGetProfileDataDeviceIntelFPGA");
    cl_int status = (cl_int)(*get_profile_fn) (device, program, false, true, false, 0, NULL, NULL,  NULL);
Updated 3 months ago
Version 4.0
