Knowledge Base Article
Why do I get an error when simulating the R-Tile Multi Channel DMA Intel® FPGA IP for PCI Express* Design Example using the VCS simulator?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4, an error will be observed when trying to simulate the R-Tile  Multi Channel DMA Intel® FPGA IP for PCI Express* Design Example for Intel Agilex® devices using the VCS simulator.
The following error message will be seen:
INFO:          497636 ns Starting DMA Read....H2D
INFO:          500949 ns Queue Reset...done
INFO:          501149 ns Waiting for MSI-X Writeback for Read DMA........
FATAL:        4000000 ns Simulation stopped due to inactivity!
                                 FAILURE: Simulation stopped due to Fatal error!
FAILURE: Simulation stopped due to error!
$finish called from file "./../..//../../ip/pcie_ed_tb/dut_pcie_tb_ip/intel_rtile_pcie_tbed_100/sim/altpcietb_g3bfm_log.v", line 144.
Resolution
There is no workaround for this problem.
This problem has been fixed starting with version 23.1 of the Intel® Quartus® Prime Pro Edition Software.
Updated 19 days ago
Version 2.0
