Knowledge Base Article
Why do I get a compilation error when my design partition contains an Intel® Arria®10 Transceiver?
Description
In the Intel® Quartus® Prime Standard Edition Software, you may see an error when your design partition contains an Intel® Arria® 10 Transceiver PHY and/or Transceiver PLL.
Resolution
The Quartus® Prime Standard Edition Software does not support partitions for Arria® 10 Transceiver PHY and/or Transceiver PLL.
Exclude the Arria® 10 Transceiver PHY or Transceiver PLL from the design block before creating the partition.
Updated 11 months ago
Version 3.0
