Knowledge Base Article
Why do Cypress* flash devices S25FL256 and S25FL512 not get programmed with Intel® Quartus® Prime Standard Edition Software version 18.1 when using Intel® Cyclone® 10 LP or legacy devices?
Description
Due to a problem in the Intel® Quartus® Programmer Standard Edition software version 18.1, Cypress* flash devices with a density of 256 MB and 512 MB will fail to get programmed correctly. The Intel® Quartus® programmer may show successful programming, but the Flash would not actually be programmed.
Resolution
To work around this problem, download and install patch 0.05 from the links below. You must install the Intel® Quartus® Prime Standard Edition Software version 18.1 before installing this patch.
Download the version 18.1std patch 0.05std for Windows (.exe)
Download the version 18.1std patch 0.05std for Linux (.run)
Download the Readme for the Intel Quartus Prime Standard software version 18.1 patch 0.05std (.txt)
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition Software version 19.1.
Updated 4 months ago
Version 5.0
