Knowledge Base Article
Why do CSR read/write accesses to the H-Tile Hard IP for Ethernet Stratix® 10 FPGA IP Core take more than 100 Avalon®-MM clock cycles (reconfig_clk)?
Description
CSR read/write accesses to the H-Tile Hard IP for Ethernet Stratix® 10 FPGA IP Core take more than 100 Avalon®-MM clock cycles (reconfig_clk) as shown in simulation.
This is the expected behavior due to the 8-bit CSR interface on the H-tile Hard IP Ethernet Stratix 10 FPGA Core. Each user Avalon®-MM 32-bit interface read/write results in 32-bit to 8-bit bus data width conversion logic which causes the extra access latency.
Note: The Low Latency 100G Ethernet Stratix® 10 FPGA IP Core (soft IP) CSR interface does not have this extra latency.
Resolution
Not Applicable
Updated 1 month ago
