Knowledge Base Article
Why do compilation and timing fail when using the F-Tile Triple-Speed Ethernet FPGA IP Design Example?
Description
Due to a problem in the F-Tile Triple-Speed Ethernet FPGA IP Design Example, compilation and timing are failing in the Quartus® Prime Pro Edition Software version 23.2.
Resolution
To workaround this problem, please download the attached altera-eth-tse-hw.zip
and follow the below steps:
1: Extract the altera_eth_tse_hw.zip to altera_eth_tse_hw folder.
2: Copy these 3 files from altera_eth_tse_hw  folder to <design_example_dir>/hardware_test_design folder.
3: Open Quartus® Prime Pro Edition Software version 23.2, open the project and select the <design_example_dir>/hardware_test_design/altera_eth_tse_hw.qpf
4: On the Processing menu, click Start Compilation.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 23.3.
Updated 8 months ago
Version 4.0
