Knowledge Base Article
Why cant I use a transceiver recovered clock to feed a transmitter PLL reference clock on Altera transceiver devices?
Description
The Quartus® II Software will deliberately prevent you from connecting a recovered clock from a receiver to the reference clock input of a transmitter PLL.
The recovered clock is extracted from the clock embedded in the received datastream. As the datastream has propagated across a channel, the recovered clock will have undefined jitter characteristics which if fed into the reference clock of a transmitter PLL, may cause the transmit jitter to exceed a given protocols' transmit jitter specification.
The recommended method of implementing a recovered clock synchronous architecture is to route the recovered clock outside of the FPGA, and to pass the clock through a jitter cleaner before routing back onto the FPGA through one of the dedicated transceiver reference clock pins.
Updated 11 months ago
Version 3.0
