Knowledge Base Article
Why can't I configure my Intel® Stratix® 10 device using a . JAM file?
Description
Due to a problem beginning with the Intel® Quartus® Prime Pro software version 17.1, you may not be able to configure an Intel® Stratix® 10 device
with a . JAM file. This problem is seen both when using the JAM™ STAPL Player and the Quartus JLI utility to configure the device.
You might see the following failure message when using the Quartus®JLI utility:
Error status: Request failed
CONF_DONE pin failed to go high at device #1
No response from device
Exit code = 23... No response from device
Resolution
To work around this problem, regardless of whether you see the above error, click on the following link to download a patch for Intel® Quartus® Prime Pro Edition Software version 17.1.1.
Download patch
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 18.0.
Updated 4 months ago
Version 4.0
