Knowledge Base Article
Why can’t I connect ACE5-Lite Manager BFM to F2H ACE5-Lite bridge in an HPS Agilex® 5 FPGA IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1 and earlier, when you connect an ACE5-Lite Manager BFM to an F2H ACE5-Lite bridge in an HPS Agilex® 5 FPGA IP,  you will see an error below. The generation of the testbench system fails when attempting to generate the HPS F2H bridge Bus Functional Model.
Error: Interconnect is required but is currently not supported for the ace5lite interface type
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 5 months ago
Version 4.0
