Knowledge Base Article
Why are there minimum pulse width timing violations in the High Bandwidth Memory (HBM2E) Interface Agilex® 7 FPGA M-Series IP Design Example?
Description
High Bandwidth Memory (HBM2E) Interface Agilexs® 7 FPGA M-Series IP design examples, generated with Quartus® Prime Pro Edition 25.3 or prior, with the configuration settings described in tables 1 and 2, may present minimum pulse width timing violations.
Parameter
Value
Choose the initiator to target the NoC mapping
16-to-16 crossbar connection
Use Fabric NoC to return read responses via M20Ks
Any
Core clock frequency
'> 500 MHz' for configurations with  'Use Fabric NoC to return read responses via M20Ks' set to 'Fabric NoC will not be used by the example design'
   '350 MHz' for all other 'Use Fabric NoC to return read responses via M20Ks' values
NoC bridge hardware frequency
'> 620 MHz' for configurations with  'Use Fabric NoC to return read responses via M20Ks' set to any value different from  'Fabric NoC will not be used by the example design'
Table 1. High Bandwidth Memory (HBM2E) Interface Agilex® 7 FPGA M-Series IP Design Example parametrization
Reference Clock SignalPin Assignment
core_pll_refclk_clk
Top HBM2E
- PIN_AT41  (PLL: UIB_FBR_LEFT)
- PIN_AP33 (PLL: UIB_FBR_RIGHT)
Bottom HBM2E
- PIN_EF29  (PLL: UIB_FBR_LEFT)
- PIN_EH37  (PLL: UIB_FBR_RIGHT)
Table 2. High Bandwidth Memory (HBM2E) Interface Agilex™ 7 M-Series FPGA IP Design Example pin assignment.
The minimum pulse width timing violations are due to a combination of an oversized core_pll|core_pll|tennm_ph2_iopll-O_OUT_CLK2 (OUT_CLK) clock tree, the clock uncertainty from UIB PLLs, and the target frequency to drive core logic.
An example minimum pulse width timing report showing the violations can be downloaded here.
Resolution
Resolution:
To workaround the issue, select a different PLL to drive the example design core logic. Table 3 shows reference pins that connect to IOPLL not affected by this issue
Reference Clock PinIO BankHBM2E Location
PIN_N64Bank 3ATop
PIN_N52Bank 3BTop
PIN_G30Bank 3CTop
PIN_G18Bank 3DTop
PIN_FJ58Bank 2ABottom
PIN_FH43Bank 2BBottom
PIN_FR24Bank 2CBottom
PIN_FJ6Bank 2DBottom
As an alternative, you can adjust the core_pll|core_pll|tennm_ph2_iopll-O_OUT_CLK2  clock tree region to utilize only the clock sectors required to cover all the placed core logic in the chip. Refer to 6.6. Creating Clock Region Assignments in the Chip Planner section from the Quartus® Prime Pro Edition User Guide: Design Optimization for guidance on how to adjust the clock region.
After adjusting the clock tree, your project QSF file will have a CLOCK_REGION assignment as follows:
set_instance_assignment -name CLOCK_REGION "SX0 SY3 SX7 SY9" -to core_pll|core_pll|tennm_ph2_iopll~O_OUT_CLK2 -entity ed_synth
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 5 months ago
Version 5.0
