Knowledge Base Article
Why are the supported flash devices in the Parallel Flash Loader Intel® FPGA IP Core not explicitly listed in the Convert Programming Files utility when generating a .pof file?
Description
When generating a .pof file for a particular flash device in the Intel® Quartus® Prime software Convert Programming Files utility, select the type of flash (e.g. CFI, NAND) and the density (eg. 1Gb) which matches your chosen device.
For example, if you intend to use CFI compatible MT28EW01GABA1 flash device you need to choose CFI_1Gb Configuration device. If you want to use MT29 1Gb NAND flash device you need to choose NAND_1Gb Configuration device.
Updated 2 months ago
