Knowledge Base Article
Why are the Intel® Arria® 10 IOPLL output clocks aligned with the falling edge not the rising edge of the reference clock?
Description
Due to the problem in Quartus® Prime Software, the IOPLL simulation model will show the output clock's edge aligned to the falling edge of the reference clock, not the rising edge of the reference clock.
Resolution
This is not the behavior that you would see in silicon. It is a bug in the simulation model and does not affect hardware. The TimeQuest will analyze the timing with respect to the rising edge of the reference clock.
Updated 11 months ago
Version 3.0
