Knowledge Base Article
Why are the configuration pin names in the Quartus® Prime Pro Edition Software v21.2 different to the User Guides and Pin Connection Guidelines?
Description
Due to a problem in the Quartus® Prime Pro Edition Software v21.2, you will see SDMMC_CFG* pin names instead of AS_nRST and PWRMGT_ALERT pin names when targeting the following Agilex™ 7 FPGA F-Series devices:
- AGFA014/AGFB014 (R24A)
- AGFA012/AGFB012 (R24A)
- AGFA022/AGFB022 (R25A)
- AGFA027/AGFB027 (R25A)
You will see that the following documentation have replaced the SDMMC_CFG* pin names with AS_nRST and PWRMGT_ALERT pin names for Agilex™ FPGA F-Series devices:
- Agilex™ 7 FPGA Configuration User Guide
- Agilex™ FPGA Power Management User Guide
- Agilex™ 7 FPGA Device Family Pin Connection Guidelines
- Agilex™ FPGA Device Pin-Out Files
Resolution
A patch 0.27 is available to fix this problem for the Quartus® Prime Pro Edition Software v21.2.
Please download and install the patch below.
This problem is fixed starting with the Quartus® Prime Pro Edition Software v21.3.
Updated 9 days ago
Version 4.0No CommentsBe the first to comment
