Knowledge Base Article
Why are the “rst_tx_stats” and the “rst_rx_stats” register bits not functioning correctly when using the F-tile Ethernet FPGA hard IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the rst_tx/rx_stats register may not get cleared after reset.
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2 and later, these register bits may not function correctly, and the resultant MAC TX Statistics and MAC RX Statistics might not be cleared correctly.
Resolution
You may need to assert and deassert these register bits multiple times as a workaround until the appropriate MAC Statistics are cleared correctly.
There is no fix for this problem.
Updated 2 months ago
Version 3.0
