Knowledge Base Article
Why are Pin Assignments missing in the Nios® V/m PIO LED Toggle Example Design?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4, you may see missing pin assignments in the System QIP file of the Nios® V/m PIO LED Toggle Example Design, which is one of the pre-installed example designs in Intel® Quartus® Prime Pro Edition Software. This is due to the parallel input/output (PIO) core with Avalon® interface preset not being applied to the instantiated IP in the Platform Designer system of the design.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 22.4, perform one of the following two options:
  • Design
  1. Open the Platform Designer system and select the parallel input/output (PIO) core with Avalon® interface instance in the Platform Designer's System View
  2. From the Presets tab, click Apply to apply the preset manually. If the Presets tab is not available, you can invoke it via View > Presets
  3. Save and Generate HDL of the system
  4.  Run the Intel® Quartus® Prime Pro full compilation and re-generate the .sof file. This .sof file will contain the required pinout details which will direct the parallel input/output (PIO) core with Avalon® interface output ports to be mapped to the respective LED's on the targeted Intel Agilex® 7 F-Series Development Kit.
  • Batch mode execution of design through scripts:
  1. Open the niosv_pio_qsys_top.tcl script contained within the scripts folder of the design
  2. Comment out the line number 308. This will ensure that the presets to parallel input/output (PIO) core with Avalon® interface will get applied correctly
  3. Run the niosv_pio_qsys_top.tcl script
This problem has been fixed in the Intel® Quartus® Prime Pro Edition Software version 23.1.​
Updated 3 months ago
Version 2.0
