Knowledge Base Article
Why are PCI Express RX TLP Packets lost when using the AXI Streaming IP for PCI Express* at lower rates (Gen1/2/3)?
Description
Due to a problem in the 25.1 and earlier versions of the AXI Streaming IP for PCI Express*, RX TLP packets can be lost if the IP is generated for Gen5 data rates but is actually operating at lower rates, and back-to-back small RX TLPs are received where the TLPs appear in each segment.
The R-Tile Avalon® Streaming IP for PCI Express* is not affected by this problem.
Resolution
No workaround to this problem exists in the 25.1 and earlier releases of the AXI Streaming IP for PCI Express*.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 6 months ago
Version 5.0
