Knowledge Base Article
Why are IBIS models not generated for the PCI IO standard by the Intel® Quartus® II design software when the current strength is set to a minimum?
Description
IBIS models are not generated for the PCI I/O standard in Quartus® II if a minimum current strength assignment has been applied, as the PCI I/O standards do not support current strength control.
A warning of the form given below will be observed during IBIS file generation if a minimum current strength assignment has been made:
Warning: IBIS model for pin "pci_<pin name>" at package pin <pin location> is not available
Resolution
To work around this issue, remove any current strength assignments made to PCI I/O standard pins and re-compile the design.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
