Knowledge Base Article
Why are 50 Gbps Ethernet transceiver channels not visible in the transceiver toolkit for the Low Latency 50G Ethernet FPGA IP Core for Stratix® 10 H-tile devices?
Description
Due to auto adaptation module finite state machine (FSM) in the Low Latency 50G Ethernet FPGA IP design example, the channels do not appear in the transceiver toolkit for the Quartus® Prime Pro Edition Software version 23.3. and earlier. The problem occurs when the Enable AN/LT and Auto-Adaption mode option is turned on in the IP wizard; the transceiver toolkit operation will be interrupted when the FSM turns on and off background calibration on the Stratix® 10 H-tile devices.
Resolution
If the Enable AN/LT and Auto-Adaption mode is turned on, write 1'b1 to bit [12] of 0x325 and 0x10325 register to hold the auto adaptation module FSM to an idle state before launching the transceiver toolkit so the transceiver channel appears in the transceiver toolkit. Close the transceiver toolkit, write 1'b0 to bit [12] of 0x325 and 0x10325  register to re-start the auto adaptation module FSM so the system console doesn't hang.
Below are the steps to be followed while using the Low Latency 50G Ethernet FPGA IP design example, target Stratix® 10 H-tile device and turn on the Enable AN/LT and Auto-Adaption mode option.
  1. In the system console, type cd hwtest to navigate to the TCL scripts folder.
  2. Type source main.tcl to load the main.tcl file.
  3. For multi-channel Low Latency 50G Ethernet FPGA IP design example,
    1. Execute command reg_write 0x325 0x1000 for channel 0.
    2. Execute command reg_write 0x10325 0x1000 for channel 1.
  4. Launch the transceiver toolkit, then transceiver channels for 50 Gbps are seen.
Follow these steps after using the transceiver toolkit:
  1. Close the transceiver toolkit.
  2. For multi-channel Low Latency 50G Ethernet FPGA IP design example,
    1. Execute command reg_write 0x325 0x0000 for channel 0.
    2. Execute command reg_write 0x10325 0x0000 for channel 1.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
