Knowledge Base Article
Why am I seeing simulation failure for GTS Dynamical Reconfiguration Controller IP designs when using Cadence* Xcelium* simulator?
Description
Due to a problem in the Cadence* Xcelium* simulator version 24.09.004, you may see simulation failure for GTS Dynamic Reconfiguration Controller IP designs. This problem is seen in the Quartus® Prime Pro Edition software version 25.1.1.
Resolution
To work around this problem in the Quartus® Prime Pro Edition software version 25.1.1, you need to use Cadence Xcelium simulator version xcelium 23.09.004.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 4 months ago
Version 3.0
