Knowledge Base Article
Why am I seeing error for GTS CPRI PHY FPGA IP Example Design with Development kit option enabled for 24G or 12G rates in the Quartus® Prime Pro Edition Software version 24.3?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3, the GTS CPRI PHY FPGA IP GUI allows users to generate a Development kit-based Example Design with 24G and 12G rates, even though the Agilex™ 5 E-Series Development kit does not support 24G and 12G data rates.
The GUI should block these configurations, but it does not in the Quartus® Prime Pro Edition Software version 24.3.
Resolution
To avoid this error, please select only 10G or below rate while generating the GTS CPRI PHY FPGA IP Example Design with Development kit option selected.
This problem is fixed in 24.3.1 release of the Quartus® Prime Pro edition software.
Updated 11 months ago
Version 3.0
