Knowledge Base Article
Why am I seeing “cmdline::getoptions“ error during the compilation stage for the F-tile Direct PHY designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 24.3.1, you may see a “cmdline::getoptions“ error during the compilation stage for the F-tile PMA/Direct PHY designs. This is due to a missing command in the sdc file.
Resolution
For a workaround for this problem, follow the steps below:
- Create a file “workaround.sdc” in your project directory
- Add the below line to the “workaround.sdc” file:
“package require cmdline” - Open your .qsf file and include this file before any other .sdc file:
“set_global_assignment -name SDC_FILE workaround.sdc” - You should be able to recompile your design now without the “cmdline::getoptions“ error.
This problem is scheduled to be fixed in a future version of the Quartus® Prime Pro Edition software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
