Knowledge Base Article
Why am I observing Avalon®-MM BFM assertion failure for the GTS Dynamic Reconfiguration design?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1, your design might fail the Avalon® Memory-Mapped (AVMM) read operation of the GTS Dynamic Reconfiguration Controller IP. This is due to the o_host_avmm_readdatavalid signal will assert when the i_host_avmm_read signal is still high.
Resolution
To work around the above problem, you should delay o_host_avmm_readdatavalid and o_host_avmm_readdata one clock cycle before consuming the result.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 4 months ago
Version 4.0
