Knowledge Base Article
Which tDQSS timing parameter should be used in the UniPHY LPDDR2 IP Memory Timing tab of the parameter editor?
Description
Typically the LPDDR2 manufacturer's data sheet specifies a minimum and maximum value for tDQSS.
Resolution
Select the maximum tDQSS value from a manufacturer's LPDDR2 data sheet (tDQSSmax).
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
