Knowledge Base Article
Where can I find an LT PowerPlay project file which has been used to program the NVM of an LTC3888 for usage with Agilex® 7 FPGA devices?
Description
You can find an LT PowerPlay project file which has been used to program the Non-Volatile Memory (NVM) of the LTC3888 voltage regulator module for usage with Agilex® 7 FPGA devices in the Installer Package for the Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile).
Resolution
The Installer Package for the Agilex 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile) can be downloaded here : Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile)
The LT PowerPlay project file is located in the directory \board_design_files\main_board\LTpowerplay\boardname_LTpowerplay_with_fpga.proj
Updated 3 months ago
Version 4.0
