Knowledge Base Article
When using the R-Tile Avalon® Streaming FPGA IP for PCI Express* in PIPE Direct Mode, why do I observe unexpected rxdatavalid toggling after P1 to P0 transition?
Description
Due to a problem in Quartus® Prime Pro version 24.1 and earlier, when using the R-Tile Avalon® Streaming FPGA IP for PCI Express* in PIPE Direct Mode, unexpected toggling may be observed on the rxdatavalid signal when transitioning from a low power state (P1) to a normal operation (P0).
This problem may also impact the symbol lock in the PCS block.
Devices Affected are listed below:
AGIx019R18Axxxxx
AGIx023R18Axxxxx
AGIx022R29Axxxxx
AGIx027R29Axxxxx
AGIx022R31Axxxxx
AGIx027R31Axxxxx
AGIx041R29Dxxxxx
Resolution
No workaround for this problem exists. Link re-training is required.
This problem has been fixed in version 24.2 of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
