Knowledge Base Article
When using the Intel® Arria® 10 FPGA in Direct To Application (DTA) configuration mode and the Application image is corrupted, will the FPGA configure back to the Factory Image?
Description
Yes, when using the Intel® Arria® 10 FPGA in Direct To Application (DTA) mode, even if the START ADDRESS on the flash device is pointing to an Application image (DTA) which is corrupted, the fallback mechanism takes place and the FPGA will configure the device with the Factory image.
Resolution
This information is included in the Remote Update Intel® FPGA IP User Guide.
Updated 1 month ago
Version 2.0
