Knowledge Base Article
What voltage should be connected to VCCH_SDM when using an Intel Agilex® 7 device with both R-tile and F-tile?
Description
Connect 0.9V to VCCH_SDM when using an Intel Agilex® device with both R-tile and F-tile.
In Table 7 of the Intel Agilex® Device Data Sheet, the typical voltage of VCCH_SDM for E-tile, P-tile, and R-tile devices is 0.9V, and the typical voltage of VCCH_SDM for F-tile devices is 0.8V.
However, it doesn't mention Intel Agilex® 7 devices with both R-tile and F-tile.
Resolution
Connect the correct voltage to VCCH_SDM depending on the configuration of transceiver tiles in the Intel Agilex® device.
The above information will be added in a future release of the Intel Agilex® 7 Device Data Sheet.
Updated 11 months ago
Version 3.0
