Knowledge Base Article
What slew rate control of the TX output signal of the Intel® Stratix® 10 L-tile and H-tile device transceiver should I use when disabling “Use default TX PMA analog settings”?
Description
You may want to use the appropriate slew rate of the TX output signal according to the data rate for your Intel® Stratix® 10 device transceiver links.
Resolution
According to the recommendation table below, you can choose the TX output signal slew rate in the short-reach link.
Table 1: Slew Rate selection table
Datarate (Gbps)
Slew Rate
Datarate < 1
slew_r1
1 <= Datarate < 3
slew_r3
3 <= Datarate < 6
slew_r4
6 <= Datarate
slew_r5
Updated 1 month ago
Version 2.0
