Knowledge Base Article
What is the signal description for the rxm_irq port when using the Stratix 10 Avalon-MM mode of the PCI Express Hard IP core?
Description
Due to a mistake in the 2017.05.08 revision of the Intel® Stratix® 10 Avalon®-MM Interface for PCIe® Solutions User Guide, the rxm_irq port descrtiption is missing.
Resolution
The following information will be added to the next update of the documentaiton:
Connects Qsys interrupts to the Avalon-MM interface. This signal is only available for the Avalon-MM when the CRA port is enabled. A rising edge triggers an MSI interrupt. The hard IP core converts this event to an MSI interrupt and sends it to the Root Port. The host reads the Interrupt Status register to retrieve the interrupt vector. Host software services the interrupt and notifies the target upon completion.
Qsys-generated variations have as many as 16 individual interrupt signals (<m>≤15). If rxm_irq_<n>[<m>:0] is asserted on consecutive cycles without the deassertion of all interrupt inputs, no MSI message is sent for subsequent interrupts. To avoid losing interrupts, software must ensure that all interrupt sources are cleared for each MSI message received.
Updated 25 days ago
Version 2.0
