Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 25.1?
Description
The latest device firmware for Quartus® Prime Pro Edition Software version 25.1 is available for download below.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Starting from the 25.1 build, N5X will no longer receive firmware updates.
This means that while your device will continue to function on its current firmware, it will not receive new features, performance enhancements, or security patches from this version forward.
Change Log
Firmware version 0.35fw:
This patch fixes potential failures observed when loading factory image with State 0xf0040074 Error location
Firmware version 0.25fw:
This patch fixes a rare scenario issue where the Agilex® 7 FPGA F-series device hangs when reconfiguring back-to-back. The fix includes an update to the polling scheme in firmware to address the issue.
Please also see the following links:
Resolution
Download the latest device firmware below.
Note:
  • Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
  • Recompilation is not required.
  • All programming files should be recreated.
    • Re-run the programming file generation or conversion using the Quartus® Prime Software programming file generator.
Updated 4 months ago
Version 5.0
