Knowledge Base Article
What is the earliest stage of compilation that I can generate a timing netlist?
Description
If you are using the Intel® Quartus® Prime Pro Edition software you can create a timing netlist after the fitter plan stage, if you are using the Intel® Quartus® Prime Standard Edition software you can create a timing netlist after the analysis and synthesis stage.
In the Intel Quartus Prime Standard Edition software, use this command to generate the timing netlist:
create_timing_netlist -post_map
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
