Knowledge Base Article
What does the i_txclkdivrate input port in the GTS PMA/FEC Direct PHY IP do when SATA/SAS configuration rules are selected?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3.1, the i_txclkdivrate input port to be unintentionally exposed when SATA/SAS mode is selected via the PMA configuration rules in the GTS PMA/FEC Direct PHY IP. This port does not require user control when operating in SATA/SAS mode.
Resolution
To work around this problem, you can tie this port to GND (ground) when operating in SATA/SAS mode.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.1
The port has been removed and has been controlled internally by the GTS PMA/FEC Direct SIP.
Updated 3 months ago
Version 6.0No CommentsBe the first to comment
