Knowledge Base Article
What can I do if the ALTGX_RECONFIG IP reconfig_busy signal is stuck high on Arria II, Cyclone IV, or Stratix IV transceiver devices?
Description
If the transceiver ALTGX_RECONFIG IP reconfig_busy signal is stuck high on Arria® II, Cyclone® IV, or Stratix® IV transceiver devices, you can enable and assert the ALTGX_RECONFIG IP reconfig_reset signal.
Resolution
You can enable the reconfig_reset signal on the ALTGX_RECONFIG IP using the instructions below.
- Open the ALTGX_RECONFIG IP.
- Enable \'Channel reconfiguration\'.
- Enable "Use \'reconfig_reset\'" in the \'Channel and TX PLL reconfiguration\' page.
- Press \'Finish\' to generate the IP.
- Connect a synchronous reset signal to the reconfig_reset port.
The following rules apply to the reconfig_reset signal:
- The reconfig_reset signal must be synchronous to the reconfig_clk clock.
- The reconfig_reset signal must be high when the device enters user mode.
- The reconfig_reset signal must be asserted for at least one reconfig_clk clock cycle.
Related Articles
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
